tjlazer said:Put up pics with those springs Booner! They might make me put them on my car after all 8)
If my brakes turn out to be ok, I will be coming to the trackday evening on the 16th, so can show you there if my photos don't help
Booner said:Cheers guys, about to order with the following prices:
bminiparts -
Z4 M OEM Discs all round - £522 inc del
Motorsportsworld -
EBC Redstuff pads all round - £142.50 inc del
Eibach lowering springs kit (20mm front, 10mm rear) - £160
I have been recommended a local garage by MrGringo on here, who will fit all discs, pads, springs and also do the CDV joint in 5-6 hours, £175-210 fitting. Is that about right?
Then I will be looking at the hunter alignment...![]()
Booner said:I have bedded the pads and discs and they seem to be ok, although I do get squeal at low speeds occasionally. I think they state 200 miles for full bedding in, if not I am going to get them looked at again.
The springs are just right, the car sits at the height that it should do from factory imo, feeling more planted and lower. I need to spend a bit more time driving in my daily conditions, but as far as I can tell, they dampen the bigger bumps more and it feels more rigid, less floaty.
Sitting lower after getting VPOWER, then some ferrari placed a shadow over my little Z4 M:lol:
