Well I went ahead yesterday and fitted HIDs to replace my dip beams. They were these http://www.hids-direct.co.uk/h7-canbus-pro-hid-conversion-35w-kit-1/
Luckily I had a spare headlight unit so I could find the best place for the ballast.
Decided to attach the ballast using the double sided sticky pads supplied to the vertical side closest to the radiator.
New fittiing clips were supplied with the kit
But decided to reuse the originals by filling out the centre of the clips to accommodate the new wiring/connectors
By reusing the originals I will be able to revert to using H7s easily either for the MOT or if I have a bulb out at the side of the road.
Work in progress
First side took about three hours while I figured out where to fit the ballasts and then worked out how but the second side no more than 45 minutes.
Will add some after dark shots later
Later
Work in progress
Later
