javis20 said:I have tried everything possible to code the top down with NCS Expert on USA cars. No luck. Many others have tried as well, with no success. On coding forums, I have requested for anyone that might have a non-comfort access car, with keyfob top-down working, to send me their code file so I can compare with mine. No one has yet done that.enzed4 said:I wonder if the US market E89's can be coded to lower the roof with the keyfob without comfort access (using Carly, NCS or similar), as this is easily do-able on other market's E89's (so it would seem to be a software setting that doesn't require the CA option). There may be an answer to this on this forum but I can't be faffed hunting for it right now....javis20 said:I have a 2011 E89 and roof operation depends upon what country your in. Here in the USA, you cannot open the roof with the keyfob unless you have the comfort access option.. You can code it to open all the windows and fold in the mirrors, but that's it.
However, I'm told that you can open the roof with the the physical key, but have not tried it. Insert key, turn to open and hold. Again I have not tried this.
To do what you want, you would need the SmartTop option. Or there is a german cheaper alternative, but requires wiring.
Holy Grail option would be to code the roof to go up with the remote, without Comfort Access. Many have tried, none have succeeded (to my knowledge) :lol:
As I previously indicated, there is a German company with a module significantly cheaper, but requires significant wiring ability. And to be honest, I could probably program an arduino to do this, but the time and effort is just not worth it to me.
I Have top down without comfort, uk car and I can send you a copy of anything you may need it you can PM me how to get the files, I’ve only used NCS expert a few times so it would help to know which files and how to save them,
