Firmware V6.02-7045 and User Guide
mac27040
Veteran
 Shepshed
Changes from V6.02-7041
User guide split into main User guide and Extras supplement.
Internal changes to allow firmware programming at the factory.
Added extra trap for Over Heat warning being disabled or having an invalid value.
Added control for Rear Side Lights on the X5.
Changed interlock on FTP to use the rear lights rather than the dip beam state, this enables FTP when Dip beam is used for DRLs.
Fixed bug when using an 'Aux' source. Menu option for the previously selected source type were displayed.
Added option on Exit Lights to trigger only when the Rain and Light sensor would have turned on Auto Lights.
Change to CD status poll response from the BM54 radio to enable the CD Changer source to be selected if the radio was turned off and then on again with the radio source selected.
http://www.muga-uk.co.uk/intravee/fw-app-256-extras-v6.02-7045.zip
http://www.muga-uk.co.uk/intravee/intravee_extra_features_Supplement_v6.02-7045.pdf
http://www.muga-uk.co.uk/intravee/intravee_PXA_Supplement_v6.02-7045.pdf
http://www.muga-uk.co.uk/intravee/intravee_users_Guide_v6.02-7045.pdf
http://www.muga-uk.co.uk/intravee/intraveeUtilities.zip
Hi there,
Just followed a link onto this thread from the "Intravee Extra Features" thread: http://www.z4-forum.com/forum/viewtopic.php?f=2&t=36604&hilit=ipod
Unfortunately the links in this thread seem to be dead. Where is the best place to get the above files now the intravee site is down?
Thanks,
Changes from V6.02-7045
Added invalidation of ID3 tags on receipt of broadcast ID3.
Added debug printf when processor volume reported is not the volume requested.
Added 1 second timer on setting the processor volume, if the timer times out then the volume request is sent again.
Added debug printf on changing the processor source.
Added option to display the Journal and Vehicle Status in full screen mode on a MK IV Nav.
Added PXA Direct option which when selected causes the AI-Net port to be used when the Intravee source is selected.
Added switch of Processor source when PXA Direct is selected and a Nav command is detected.
Added light sensor trigger level for Entry and Exit lights, the will probably only work on the E46, maybe the Z4 and X3.
Added retry up to 10 times on sending light control messages if no Ack is seen.
Changed the mechanism for display disable when Intravee is paused for Phone or VR.
Change to FID audio menu update frequency.
Changed OPARM version to 64.
Fixed bug when changing the processor volume while reduced (in reverse) changing the volume now cancels the reduction.
Fixed bug when setting the clock from the Nav when the TZ setting was more then 9.5 Hours or less then -9.5 hours.
Fixed bug that caused the Nav type to be requested on power when in auto UI mode up even if the Auto Nav type setting was not selected.
Fixed bug that prevented VR commands being heard when using PXA Direct mode.
Removed debug printf on Net App restart.
http://www.muga-uk.co.uk/intravee/f...o.uk/intravee/fw-app-256-extrasv6.02-7058.zip
http://www.muga-uk.co.uk/intravee/i.../intravee/intravee_users_guide_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/i...avee_extra_features_supplement_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/i...travee/intravee_PXA_supplement_v6.02-7058.pdf
http://www.muga-uk.co.uk/intravee/i....muga-uk.co.uk/intravee/intraveeutilities.zip
