The first thing we do when we arrive on a marshal post is to check that the powder extinguishers are not 'caked'. About 1 in 10 is stuck so much that we have to request a replacement.
The AFFF (foam) ones are usually not a problem.
If you have a powder extinguisher in the car/home, then please ensure you regularly check that the powder hasn't become ’caked' in the extinguisher.
To check, simply hold the extinguisher in its stored orientation, place it against you ear and invert it. If you don't hear the powder sliding/whooshing in the casing, then give the base ia couple of taps on the floor and try it again.
If it still doesn't unclog after a few attempts, then it's unlikely to work when you need it most.
The only thing worse than having no fire extinguisher is having a non-working one - as you'll be tempted to tackle the fire with a false sense of security.
(where I am now) as well as a first-aid kit, bulb kit and hi-vis vests, which have to be in the car so you can put them on before exiting :roll: . My extinguisher is in the boot like most people but I have seen brackets to mount infront/under the drivers seat.
