:lol:Pondrew said:Look to the south and you will see the glowLeeZ4MR said:I've had to put my sunglasses on after looking at the wood to be fair!
I have to say that it does absolutely immaculate inside and out for sure.![]()
It's not immaculate, but won't take too much to get it back to that. I'm wire-wooling the inside of the exhaust tips ATM to try and get the burnt-on crud out. I'll start cleaning the leather next. :|
Nearly hit something in Halfrauds' car park earlier as I didn't realise it doesn't have front PDC (only rear).![]()
Flyingfifer said:I've always thought of the Alpina BMWs as the sort of fat, comfortable cousin of M BMWs
I've been at it half the day with the wire wool. Didn't work, as the two 'main' exhausts have got 'heat tarnished' so have changed their colour internally. Back to plan A, painting all four internally with matt black stove paint.pvr said:Oh, and for the exhaust use the drill with 0 wire wool attachment. Works a treat with no effort
Are they still in good enough condition to keep the tip edges chrome? Or are you going all black?Pondrew said:I've been at it half the day with the wire wool. Didn't work, as the two 'main' exhausts have got 'heat tarnished' so have changed their colour internally. Back to plan A, painting all four internally with matt black stove paint.pvr said:Oh, and for the exhaust use the drill with 0 wire wool attachment. Works a treat with no effort
Yes I've polished up the outers and the lips, they are OK; it's the insides that are the problem, two are one colour and two are another (I think I may have a bit of OCD)LeeZ4MR said:Are they still in good enough condition to keep the tip edges chrome? Or are you going all black?
Don't be-little your wood, Ian. Your wood is as good as the next man'sMr Tidy said:That's quality wood.
It certainly looks better than what I have in my E90.
Pondrew said:Actually, you may be able to help; I can't find any way of adjusting the instrument lighting brightness. Is there?I can adjust the Idrive brightness but that's all.
Pondrew said:Don't be-little your wood, Ian. Your wood is as good as the next man's
Actually, you may be able to help; I can't find any way of adjusting the instrument lighting brightness. Is there? I can adjust the Idrive brightness but that's all.
Thanks Ian. I will give a go. My Idrive is the very first incarnation, I think. It's amazing how the tech moves on so quickly. This is the first car I've had for about 15 years with a manual handbrakeMr Tidy said:Anyway onto the instrument lights brightness. You need to have the lights on, then press the button on the end of the indicator stalk to get into the OBC settings then scroll through with the "up/down" rocker on the stalk until you get to the right display and adjust using the button.
But as you have i-drive it may be tucked away somewhere else.
Pondrew said:Thanks Ian. I will give a go. My Idrive is the very first incarnation, I think. It's amazing how the tech moves on so quickly. This is the first car I've had for about 15 years with a manual handbrake
Same with the wood Pondrew.pvr said:Oh, and for the exhaust use the drill with 0 wire wool attachment. Works a treat with no effort
I won't hear a bad word about my woodBeeEmm said:Same with the wood Pondrew
