Trying to insert pins into this TE MQS Sealed connector and having difficulty. I've easily inserted pins 1,2,5, 6 with the pink tpa lock pressed outward.
Pins 3, 4 that are right next to the tpa locks are still barred from seating.
It seems like the outer shroud should be removable, giving the pink tpa more room to unlock, but I cant fid a way to release the outer shroud.
I'm certain that @AnubisZed has at least pinned this connector for a PDC retrofit (Wire loom AB to AB2 connector) but I'll wecome a response from anyone.
