colb said:Strange they are all showing bad signal and a duff heater on the one, check the wiring connections first, disconnect and spray some contact cleaner in before lashing out on replacements. Once cleaned clear the codes and see if any come back. I would expect the duff heater one will come back if the heater circuit in it is burnt out.
colb said:Been having a trawl around the web regarding your codes particulaly the No Signal codes, possibility there is a fuse gone in their circuit, have you checked for blown fuse, maybe a 30amp fuse. Check the main fuse board and the ones in the box in engine bay.
Might be a good idea to view the sensors in live data with diagnostics to see if there is any activity with the engine running, if they are flatline then that may well point to a blown fuse.
