Fault code 611A
Otzie
New member
 Amsterdam
Hello all,
I am looking for a solution to the problem I am having. Sometimes when I start the car I get an eps warning light. When I restart the car, the light goes off and everything works again. After reading all the posts on this and other forums about the dreaded eps module, I got the eps module out of the car and sent it in for repair. unfortunately the ecu repair center has indicated that there is nothing wrong with the module. They recommend looking for the problem further in the car.. :headbang:
The faultcode im getting after reading the car with ista is 611A. I noticed that most error codes about the module end with 611C,611D. Nowhere can I find the same problem with error code 611a. Does anyone have any idea where i should look to fix this issue?
