Failed MOT
Springs are about £25-£40 on the aftermarket and are literally 10 mins to fit (if its a rear)...
What are they saying is causing the brake imbalance? Front or rear imbalance (Usually fronts)...Front Calipers are around £70 each,and pads under £15 at ECP..
They may charge around 2 hours labour.....Then the dreaded 20% VAT...
So,could be cheaper but not too far off i would have thought..
Maniac said:
DrNick said:
Ah whoops!
Thought you were going to suggest that it failed due to lack of cylinders Maniac, :P
Mods please feel free to move appropriately!
That was the old Maniac, the new Maniac keeps his mouth closed on such topics and lets others have their turn in the fire. :poke:
If there's only a small oil weep I'd not stress too much - the much lower pressure from only 4 cylinders will ensure it stays as 'weepy' for a long time. Probably at least 5 years :P
Feel better now someone's had a pop ? :D
Oil leak from Vac pump on rear of engine is really common......The actual case of the pump goes porous and weeps oil..
FWIR the pumps are around £325 from the dealers..
I had an advisory on front wheel balance last time, sorted with a pair of re-furbished callipers and new pipes for good measure as the discs and pads were new. As you say not unexpected on a car that's 10+ years old I suppose but still a nuisance.
DrNick said:
There is also an advisory that there is "oil weeping from O/S/R upper engine, vacum pump area" - any thoughts on what this could be/mean??
I have the same, as you look at the engine from the front it is at the top rear of the engine on the left. I bought a new vacuum pump from Ebay but have not fitted it as yet. You can reseal it mine lasted 3 years but has just started again so I will probably fit the new one.
Bing said:
Maniac said:
DrNick said:
Ah whoops!
Much - thank you Bing!
Will it cause I problem if I just ignore it long enough till I decide if I want/can afford to change the car or not?
Ok - thanks - ill have a look at some point when I get the chance.
