Failed anti-theft system
Mike W
I have an 03 2.5L with about 104K miles. The last time I took my car in to my mechanic, he told me the anti-theft system was not working. He had no idea how it could be working one day and then just stop. Has anyone else had their system fail? If so what was the cause and the fix? I don't feel disposed to spending another $1K in repairs for this fix after just spending that to replace the fuel pump and filter.
With any electrical issue, especially strange ones, always suspect these possibilities: blown fuse, dirty, wet, and/or corroded connectors, rodent damaged wiring, weak battery. In some cases, a faulty relay. You can get more information on electrical systems from the Wiring Diagram System (WDS). It's available online at http://www.bmw-planet.com/diagrams/release/en/e85/index.htm
The navigation is Java based. You may get a warning that your browser has disabled Java due to security issues. This site is safe, but others may not be. Consider re-enabling it for this site, then disabling when you're done. It may simply not be possible to use on mobile browsers.
