v8z4 said:Well, how do you want to setup the system? Do you want to retain the 'rear' (the mids behind the seat) speakers? If so, then you need a 3-way crossover. If not, then a 2-way will work.
for the hassle, the retention of the rear mid wouldn't have much of a point given the limited potential of the driver.
as for my testing with the rear speakers I'll be attempting to achieve a punchy midbass response from my install, there is no intention for sub bass (I interchange a 10w7 and two 8w3's to take care of the sub bass frequencies)
Personally to the OP, you're better off rewiring the car. If it was myself on a budget, I would have a pair of 6.5 2 way components up front (run from the headunit bypassing all OEM wiring)
I would also specifically choose a pioneer headunit with the Direct Sub Drive technology and specifically a pair of Hybrid Audio i6SW for the subwoofers
This set up wouldn't require the need for additional amplifiers or the such however will allow the potential for a great affordable sysem that will sound great.
Johnny - Sure adding an amplifier would really do the system a word of a difference but it's not something that is essential if trying to keep things simple and cost effective. In lay terms an amplifier will increase headroom for the power sent to your speakers, resulting is more clean (undistorted) power sent to the speakers.
Personally, I would have an amplifier, a 3 or 4 channel. 1 and 2 for a pair of components and channels 3 and 4 bridged for two subwoofers run in mono channel (as some amplifiers are able to increase their power output when bridged)
