spoke to eurocarparts today and was advised that they supply the front fog lamps for Si 2006 model. they say the lights are genuine item(not aftermarket) made Italy and need to be ordered which takes roughly 7-10 days, quoted me approx £62 each, during phone call was advised they could obtain 1 light. has anyone went this way or should I go main dealer at £100+each? after reading lots of posts on here discovered that my light in central storage box was also on, broken plastic part on door bottom, took door off and in process the arm from microswitch dissapeared down the black hole. spent lot of time trying to remove that panel to retrieve same arm without success, anyone know if the microswitch is available?
Many thanks
Many thanks
