enuff_zed said:Oh and I love how easy the M54 is to work on
Indeed they can. And if it's raining you can close the bonnet and let them out when they're finished.Argyll Andy said:enuff_zed said:Oh and I love how easy the M54 is to work on
Even a 7-9 year old can work on them :wink:
brillomaster said:i also prefer pre facelift, i do prefer the way the rear lights look pre facelift.
also, the M54 engine is pretty bulletproof, wheras the N52 engine will definitely require a new water pump at some point.
Yes I was going to say the same. I had to replace the water pump on our 2.5i a few months back.Smartbear said:brillomaster said:i also prefer pre facelift, i do prefer the way the rear lights look pre facelift.
It’s not just electronic pumps which can fail, i replaced the mechanical water pump on mrs smartbears Yeti last week after only 28k miles!![]()
enuff_zed said:Yes I was going to say the same. I had to replace the water pump on our 2.5i a few months back.Smartbear said:brillomaster said:i also prefer pre facelift, i do prefer the way the rear lights look pre facelift.
The difference being that you get a warning leak from the tell-tale hole under the bearing whereas the N52's just stops!
