F10 M5 illuminated ZHP install guide with photos
MickAdams said:
srhutch said:
How come the stitching is the opposite way round to each other on these last two?
I thought the boot was attached to the knob. :?
I think JAD has taken the knob off and is using it with the standard gaiter, I've used the gaiter that came with it and fitted that around the Z4 hoop.
Correct, Mick. I didn't want to change the gaitor as (no offence to those that have) I've not seen one that has been either easy or provided a perfect outcome.
HOW VERY DARE YOU!?! I think mine has come out looking pretty stock :P
Before I did mine, I had a good look at all the pictures I could and decided I'd have a better chance of getting it looking good keeping the gaiter and knob attached, I couldn't see a way of getting the fold at the top of the original to look as good as the original join it comes with. Both ways looks good though :)
Actually I take that back - yours is the best I've seen I have to say. I'd skipped a page and looked at NCrossy's (again, no offense :thumbsup: ).
What, several who used the F10 gator, look really good including mine, some not so much. Easy, depends on your skill level, I thought it was pretty easy, but if you're lacking the skills, yeah, it might not be very easy. The leather on the F10 it much nicer than the stock leather, so it's well worth the effort if you have the skills to do it right. :thumbsup:
That's what I would do to. Makes it easier to revert back also. Presume you had to cut the gaitor off.
I cut my gaitor off & the 3 tabs holding it to the knob, found a post on M3Cutters.
Decided to do it this way incase I wanted to put it back to original if I sold it.
I easily removed the original gator without destroying it using a heat gun to soften the glue. I'll keep it in in case I ever want to return it back to original, although I doubt I ever will.
I did this too, although I can't imagine I'd ever actually change it over again. If I did ever need to get it back to be totally stock I'd just buy a new one, and I'd need a new knob too. I'd imagine someone would have the converted one I have off me :)
Beedub said:
when i see a diy written like this with true passion as well.... = marriage material....
nina!!! very impressed!!!!
so the wiring is plug and play??
i like mods like this where time time and effort is done away from the car.
+1 :thumbsup: ripped mine off so I'll need to give those wires a bit of TLC. Is that new gear lever much bigger than OEM? How does it feel in the hand?
It's just shorter, so looks "chubbier" - it really has made a big difference. I've started keeping my hand more on the gearknob than the wheel in a more relaxed position!!
The gear knob which came with my car is an illuminated ZHP. I take it this isn't stock after reading this post.
I want to get the F10 knob I think. Am I right or wrong to think this more weighted.
Thanks in advance. :thumbsup:
I like the look of the stubbier gearknob as well as reducing the throw. The main reason I have in my head is I feel my current heartsick is too light and want something heavier, more positive. The leather also has seen better days on my current.
My last car I had a billet knob which was great but don't want to away too far from stock.
Sounds like you have the standard illuminated knob, not the zhp.
If there is no chrome ring at the bottom of the knob it's the standard one.
I have an illuminated version of the one on the left.
Aghhhhhhh
Why oh why did I read this!!
Felt me gator leather or glorified paper earlier and damn it want it replaced now haha
Great install guide btw!!
Wish there was one for when I fitted my audiovox media bridge and pulled roof release!!
Arse Of a job that was to put right
Question..
As a few posts have said weight different etc I have a comparison size and weight pic from makers of the zhp shifter
Pic of shifter is original m5 shifter note 4 split of leather
So what is the actual diffence? Is it the illumination?
As I don't know if oem has illumination
Anyone?:)
That's interesting. The weight difference is only 0.3 oz. think I am going to order my F10 tomorrow.
I do research first haha
Thing is ones oem and one zhp
But I don't know if oem is illuminated
As oem one now has 4 way split in gator of which will for nicer in original z4 frame as its 2 way split but reversed on f10 leaving gaps when shift forward
