I've just finished doing my clear indicator conversion, I've got these left over from the doner lights, one of the tabs has a bit broken off the end, around 5mm of plastic, it won't be seen when fitted and won't effect the light, I should know I cut this tab in half when opening my original lights
May be good for some one wanting to swap from silver to black Inners. £20 posted
80mm Angel Eye CCFL rings, 3mm thick, white with a hint of blue. I decided against doing an AE retrofit, I've got 7 ccfl rings and 3 inverters so enough for a set of lights and a coupld of spares, the rings sit really neatly around the lights. £40 posted
Drop me a PM if your interested.
