F/S 330Ci/Z4 3.0si Caliper £10 Collected
Hi Ash, I could be interested in taking the leather gaiters from you, but not sure the arm rest portion will fit my existing trim.
My Z is a 2004 without arm rest and studying your photos its not clear where the clips on the underside of the rest are mounted in, are there slots in the trim where the arm sits?
If that's the case and I don't have them, would double sided tape secure it?
Hi mate not sure what you mean, any chance you could remove yours and send me a pic?
I would be surprised if the trim wasn't the same to be honest.
The handbrake gaiter is all one piece on the one I have and it just clips in an out.
Ash
ekimj10 has first refusal on gaitors
john-z4 has second refusal depending on ekimj10's decision.
Ash
Hi Ah,
Thanks for response, have looked at my arrangement and unfortunately there is no obvious provision for clipping the arm rest into the trim. Its a bit weird as the OEM diagram shows an arm rest (item 4) fitted.
Sadly I will have to duck out, but appreciate your efforts, they are a good buy for someone.
BUMP if no one wants it ill bin it, this is ideal for a front brake upgrade, you only need the otherside from ebay or a breaker and your ready to go.
ill get a postage quote, but it isnt light which is the issue, i can imagine postage costing a bit I can do it for £25 posted if that helps you out
