A Anmarube Active member Atherstone, Warwickshire. Jun 24, 2018 #1 Does anybody know where I can buy some from. 20mm and 12mm spacers? Cheers Russell
A Anmarube Active member Atherstone, Warwickshire. Jun 24, 2018 #2 Sorry wrong section. Meant for E85.
A Anmarube Active member Atherstone, Warwickshire. Jun 24, 2018 #3 Anyone know where I can buy some. 20mm spacer 12mm spacers. Cheers Russell
D Double Zero Member Milton Keynes Jun 24, 2018 #4 I got mine from http://www.trsuk.co.uk/shop/ Called up let them know size of spacers bolts arrived great service I think they have an ebay shop too.
mmm-five Lifer Liverpool Jun 24, 2018 #5 Don’t know if you’re a member, but have you seen this post in M3Cutters?
A Anmarube Active member Atherstone, Warwickshire. Jun 24, 2018 #6 Thanks a lot pal. Will give them a call. ...
A Anmarube Active member Atherstone, Warwickshire. Jun 24, 2018 #7 mmm-five said: Don’t know if you’re a member, but have you seen this post in M3Cutters? Click to expand... I'm not but will have a read. I mistakenly posted on the E89 section and a forum member replied with great advice too. Cheers Russell
M MACK Veteran Manchester Jun 26, 2018 #8 Mcgard do a set with 50mm long thread which is about right for use with the 20mm spacer. you can then cut down two of the bolts to suit the 15mm ones.
A Anmarube Active member Atherstone, Warwickshire. Jun 26, 2018 #9 MACK said: Mcgard do a set with 50mm long thread which is about right for use with the 20mm spacer. you can then cut down two of the bolts to suit the 15mm ones. Click to expand... Cheers Mack...
