1. You need to remove the top plastic panel which the expansion cap comes through.
2. if you are working from above only then best to remove radiator fan to give you room, there is a star bolt top left corner nearest the winscreen washer tank holding the fan in place. remove the 2 electrical connectors to the fan. Fan should now slide up.
3. remove top hose
4. remove hose halfway down.
5. remove hose at the bottom. all hoses are on spring clips.
6. there is a screw below the tank to the right, think its another star head.
7. think that's it should be able to slide expansion tank out.
8. I would recommend you check "O" rings in hoses as I replaced mine.
9. fit in reverse order, don't forget you will get a lot of water spillage unless you can catch the coolant.
10. once you have fitted it all back together, don't but large cover panel on until you have bleed the system, there is a plastic screw on top of the expansion tank, open that up and run the car till water comes out. tighten screw and you done. fit panel and finished.
