exhaust swap
imp75
 Hartlepool
does anyone know if i swap my stock 2.0 exhaust for a one off a 3.0 will i gain any benefit by way of performance or improved noise?in fact will it fit at all?
Clearly the exhaust manifold is very different on a 6 vs 4 cylinder having 2 parts running separate pipes while the 2.0 merges into a single flange, which then drops to a single pipe, so you'd have to find some point to break in at that point.
Best bet would be get an exhaust shop to make an adapter for the different bore pipes and the lambda sensor. New hangers then needed end to end.
Frankly a lot of work unless you have a full 3.0i exhaust lying around and I doubt it will make much difference as BMW exhaust are fairly free flowing anyway and tuned to their respective engine
It has been done by a forum member- he commented in better noise but no better performance. U may be better getting a custom one made to look and sound like the 3.0.
