Hi.
To get a bit more noise, growl etc on my 30i I read up on a few threads re the above. The easiest way was to remove the fuse which I have done. I then read a bit more and another way was to remove the small electronic plug attached to the valve actuator. From a Google search I see that both hold the exhaust flap open and there is no difference in the noise, growl etc. if that is correct about no difference in the noise, then why remove the electronic plug when it is easier to remove the fuse. Thanks.
