Exhaust flange corroded
Jamo96
 Swindon
Exhaust started blowing after about 15 mins of driving, got under the car to find the flange (both sides) from the down pipe is completely past it, just wondering if anybody knows anyone who would take this repair on as here in Swindon I can’t seem to find anyone, all help appreciated :D
Hi Jamo
It’s a PITA of a job!! Surly though it’s not the flange but the bolts and gasket that are badly corroded? The exhaust is Stainless steel so should be ok. It can be done at home i have done 3 off them now and it’s a horrible job to do. It can take a long time to drill the bolts out. I am not a mechanic and if you could get to me on a week day. I could possibly help out. I am in Witney but my workshop is near Woodstock. So not a million miles from you.
Usual problem for Zeds and series 3 BMWs. My MOT station recommended 'Mr Exhaust' so took my car to them and they did an excellent job. Primarily a clean up and new bolts and it looks new. Mr Exhaust said it wasnt stainless steel but a composition material which can corrode but much slower than steel. A bit of advice is to buy the gasket from BMW first and get them to use that as I hear that aftermarket gaskets are a bit smaller internally and can restrict exhaust flow. You should have a Mr Exhaust your way. Allow around £150 for the job - they should also give you a lifetime warranty.
Machine monkey said:
Hi Jamo
Ooh not a million miles away atall, I’ll get underneath the car ASAP and try and get a picture for you see what you think? The bolts are in shocking condition but thought was whole flange also. Appreciate that alot mate
Yeah having done some research I’ve found it to be fairly common, test of exhaust is completely fine though, cheers for the advice mate will have a look at the gaskets now and the nearest mr exhaust!
Ive only skim read this thread but could these be the fix?
https://www.ebay.co.uk/itm/BMW-E46-M3-Z3M-Z4M-Exhaust-Flange-Repair-Kit-4-Flanges-stainless-steel/381512112257?fits=Car+Make%3ABMW%7CPlat_Gen%3AE46%7CCars+Type%3AM3+3.2&epid=11004739425&hash=item58d3e4d881:g:XxIAAOSwHxVW69F2
Wrong end of the car. They are for back boxes on ///M’s
For £150 I would supply a set of new stainless tips. I can do the job you supply the gasgets but I would have to do it on a week day as I don’t have weekend time. So that might be a deciding factor for you.
Hi Jamo
+1 done a couple myself on 3.0's right PITA! No idea what those studs are made from, but they are bloody hard!
Mike
Hi Jamo
Mike
They are forged in Mordor I think DLV!!
Hi Jamo
Mike
:D I ended up piercing a hole through the centre of the the studs with the plasma cutter after cutting them flush and tapping them out - Gave up on drilling after the 3rd bit went dull
Mike
Mike
Mike
I have some bad ass drills. Low rpm and plenty of cutting fluid still a PITA though!!
All sorted, Bell Silencer did it for £50, gaskets £30 from BMW, not too bad, should hopefully stop the blowing
