Ex-Marlon E85 Update & Help Request
  • Thread starter Thread starter Deleted member 31920
  • Start date Start date
Has your car got wheel spacers fitted? I put them on my si and it was definitely more twitchy afterwards, if they are fitted take them off & try the car.
It has actually (unless removed by OP) - with the style 32s I put 15mm on front and 20mm on rears
kis said:
The first post explains they couldn't get it to "stock", this was as close as they could get... which isn't a bad thing IMO (M spec for alignment).
Post reads to me, that before adjustment it wasn't anywhere near stock. And now at least it is closer...
Which could then imply that the tyres had worn unevenly as a result?
As I said before, isn't there anyone close enough who could lend a pair of known good fronts for a quick test run?
OP, originally before you swapped anything (wheel or tyre) were you experiencing any issues?
I say this because I've remembered you're on a square set up. So I believe when the "old" tyres were put on the new alloys the positions have been changed. So you could have a front tyre on the rear alloy, vice versa. This could be causing the problems. As per the above, I'm not so sure the tyres have worn unevenly, just not been put back from the corner they were taken. It's important on the Zed to keep tyres on a particular corner, the swapping wheels thing to improve wear doesn't really apply to us.
If your wheels/ tyres are same back and front, it might be worth swapping front to rear.
In the past on Two occasions mine has suffered from tramlining and on doth occasions the simple swap of front to rear cured the problem.(keeping them running is same direction)
I would also agree that spacers tend to make it more susceptible to tramlining, I run 15mm front 20mm rear, does not cause tramlining but is more sensitive to road camber.
Good luck, hope you get it sorted without wasting cash on issues that may not in fact need resolving. :thumbsup:
My bad... for some reason I thought you were running a square 8J setup... :oops:
I had my E89 done here http://www.atec-align.co.uk/what-to-expect-with-a-four-wheel-alignment/
As you will see from the page it states “ Weight a car for measurement, where specified by the manufacturer.” He did weight mine so I guess it is required on our cars.
Have the shock absorbers ever been replaced and what mileage is the car on?
My Current E85 is on Eibach lowering springs, Bilstein B8’s and Z4M style 224 wheels, so it’s low with a wide track and it’s very planted. It needs a very ‘rutted’ road to do anything other than maintain forward momentum with absolutely minimal steering input. It also brakes sharply in a straight line.
The chap who bought my previous E86 is on the same suspension set up and wheels! That car doesn’t tramline now either. It did when I sold it to him, which I was completely open about and was one of the things I had planned to address if I’d kept it... but it’s now sorted.
Not saying it’s the case for your car, but a knackered shock absorber with no rebound is going to drastically affect road manners. Can’t remember how old your car it, but it’s at least 10 yrs old I’d have thought?
Just a thought. :thumbsup:
Might be worth going through some of the threads and many, many, many polls that Marlon posted to see if there's any suspension changes.
You could of course just PM him unless he's above all this now with his Volkswagen. :rofl:
n1cecupoftea said:
I have compared the three cars and any changes or tweaks made to the Z4 on the same stretch of road near me, which is particularly bumpy and rutted. I could comfortably drive the Clio and MR2 with one relaxed hand on the wheel. In the Z4 I need two clenched hands on the wheel on the same piece of road. I realise I have to accept some tramlining but I think I can improve it a bit.
That's interesting. What I forgot to mention was that my Z4 and 1 Series both tramlined most on roads with deep "ruts" from heavy HGV use, or on joints in the road surface that were almost parallel to the direction of travel - like on the concrete section of the M25.
You're right about the sound of the N52 as well - a previous owner of mine had a custom cat-back system fitted and it's great. :)
:D No suspension changes during my ownership - rear springs replaced by previous owner
(p.s. my 997 gen1 was the last model built and owned entirely by Porsche :wink: )
I agree with Rob. With spacers fitted (F15 R20) on standard wheels mine was noticably worse to drive. Shame as they do look better. The tramlining was also amplified. Google scrub radius for an explanation of the root cause on the front and extending the suspension lever point on both the front and particularly the rear doesn't help either as it reduces the effectiveness of the springs/shocks.
When I got my car ten years ago it had epic and dangerous tramlining on it's original worn runflats, a change to Falkens and a 4 wheel alignment cured it. A few years later I swapped to staggered 18's with Goodyear Eagles and tramlining was back. I then spent 12 months going through new rear springs, lots of bushes including lollypops and anti-roll bars, track rod ends etc which got rid of most of it. Finally got it sorted with a competent 4 wheel alignment by someone who understood that it's no use using factory settings on a car which has been changed from it's factory, wheels, tyres, springs and bushes. It now runs true with no wiggle even on inside lane canyons or greasy white lines.
Having done a LOT of reading during all this I came to the conclusion that 50% of the issue is tyre construction and tread pattern. A piece I found and posted a while ago explained that the stiffer the tyre and more 'square' the edge profile the more likely it is to sit in ruts and lines and not climb out, which makes sense. Supported by my experience with Falkens, which were quite forgiving and have a rounded edge profile and were fine, and Eagles that are stiffer and square edged. So it's worth considering the edge profile when choosing tyres and getting a really competent 4 wheel alignment.
Thanks for your detailed feedback, this is much appreciated. The second alignment is being done tomorrow morning and I will make sure they weight the car correctly and reset the steering angle sensor. If that doesn't improve it, I will try without spacers and if that doesn't work my first expenditure will be on new front tyres for sure. Thanks again.
You may need to fit standard length wheel bolts after removing the spacers, longer ones are normally needed when spacers are fitted :thumbsup:
