mr wilks said:Can't see if it says with immediate effect ?
Bad timing as i depart from Dieppe next Thurs 5am for a 120 mile "exploration" of the TT's rev range & check the speedo works the whole way around the clock![]()
They do give you a sporting chance in France though as you get a speed camera sign on the roadside telling you of the camera 300/500 yards aheadmost helpful
mmm-five said:Just change your plates after you've got off the ferry/train - one letter different should do it and could be easily explained as an error should you be physically stopped.
Hope their cameras are forward facing and have decent resolution, otherwise it's going to make identifying the driver a bit an issue on a shared drive European jaunt :wink:
halifaxbantam said:mr wilks said:Can't see if it says with immediate effect ?
when you back Andy?..Fancy the catch up Sunday 01/03/2015 at the Turnpike?
mr wilks said:mmm-five said:Just change your plates after you've got off the ferry/train - one letter different should do it and could be easily explained as an error should you be physically stopped.
Or failing that a set of Srhutch's plates will work a treat![]()
on a car, it is closer than the van that keeps pretending to be him. At least the numberplate is getting to see some daylight on that van
Adamski said:Would your licence be endorsed, or just have to pay the fine?? :?
mr wilks said:I have been stopped at the roadside doing 90kmh in a 60km zone & was relieved of 90 euros cash there & then from the Gendarme
