Error code help -Airbag light on **UPDATE RESOLVED**
alane29
 Birmingham
So i converted to hydraulic steering now im left with an airbag light not sure how its related to the steering ,i also have the EPS light on but im not worried about that .
I used inpa and read and reset the codes the airbag light wont go out here are the codes and help would be much appreciated .
http://i1276.photobucket.com/albums/y472/ajlane39alane29/error%201_zpsjbl86oqt.jpg
http://i1276.photobucket.com/albums/y472/ajlane39alane29/error2_zpsvip418bb.jpg
http://i1276.photobucket.com/albums/y472/ajlane39alane29/error3_zpssgv7kyjg.jpg
Hi Op
I had a similar issue when I inadvertently turned my steering slip ring out of alignment whilst refitting my refurbished steering wheel. I can't recall the exact code but if you've had the steering wheel off at any point it may be this. It came up as an airbag communication error +1 -1( +1 being rh -1 being lh)
In effect no Comms with the steering wheel position.
To rectify I had to buy a new 2nd hand slip ring off eBay for £8
Hope this is of use
Thanks i have had the steering wheel off .
Is this the ring where the indicators are attached too .
So i resolved the issue ,i removed the airbag and found one of the connections was not connected properly ,Must have been my nervous shaky hand holding the airbag :rofl:
Reset with inpa and its gone
