liamconnolly
Hello all,
I'm looking for a bit of advice as to what could be causing my E86 to fail to crank.
Having brought it out of winter hibernation this week i can't get the engine to turn, just the starter relay clicking (no stuttering, or inclination to start, power to interior/radio/lights all seems fine).
I knew the battery wasn't in the best condition so replaced today - and even topped up the charge to make sure the new battery wasn't bad. Whilst i haven't put a multimeter on i'm pretty certain that the problem isn't with the battery, which leads me to think it could be knackered starter motor (35k car - is this likely?); EWS module failure; ignition switch; or immobiliser.
The battery has been disconnected since February when the alarm went off at night - central locking wouldn't work and ignition wouldn't reset alarm, so i pulled the leads on the battery. I assumed that the battery had discharged causing the alarm to sound(?), but perhaps the immobiliser has also kicked in? I had assumed that a new battery would reset?
I can run a diagnostic in the next few days, but was wondering if anyone had had similar experiences as to what it may be and what i can do to fix.
Thanks,
Liam
Thanks,
Liam
