All,
Quick question. Z4 3.0Si running poorly at idle (inconsistent revs, jumping up and down), but driving absolutely fine, and in the tachometer an amber engine shaped warning lights appears. The oil cap wasn't closed properly, once it was, the car seemed to idle fine and after a drive the amber engine line disappeared. Could the loose oil cap be the cause of this? Like I said, once it was properly closed, the car idled without issue. But I'm not sure how just a loose oil cap could trigger this warning light? What is the actual definition of the engine shaped amber/orangey outline in the rev gauge?
Thanks guys, appreciate any help.
Chris.
Chris.
