Hi everyone,
I’ve been experiencing a few issues lately with the Zed so I’m hoping somebody out there might be able to give me a few pointers.
It started last Friday as I left work. I started the engine and it briefly seemed to rev much higher than I would have expected before the engine settled down to normal idle.
As I pulled into the BP garage just before arriving home, the revs increased of their own accord for a few seconds so now I was certain I hadn’t imagined things previously.
As it was chucking it down (and dark) by the time I got home, I decided to look into it the following day.
It was another wet & windy day Saturday so I thought I’d see how the car behaved on the weekly shopping trip. It ran fine on the outward run but as I descended downhill on the final mile or so towards home, the engine started sounding very rough and I could hear some muffled popping coming from the exhaust on the over run.
I made it back thankfully and straight away got the Creator 310 out to check for any fault codes. What it gave me was:
2C7F DME Lambda Control 2
2A38 DME Valvetronic, Monitoring, Sluggish Movement,
I’d read somewhere (the Forum I think) that the 2C7F code could indicate air ingress in the system so this morning I did a visual check for any split / perished vacuum hoses which might be causing a lean mixture but couldn’t see anything obvious.
Is there a way I can use the Creator 310 to tell if the (downstream?) lambda sensor is working properly?
I started the engine up but everything sounded ok apart from one instance when the revs suddenly increased then decreased over a period of four or five seconds just as they had in the filling station previously.
I also removed the plastic engine cover and noticed that oil was smearing down from the eccentric shaft sensor connector. When I removed the connector I could see straight away that it was quite oily and that some oil was inside where the pins are. This was disappointing to see as I’d only had a new sensor fitted in March of this year and they are not cheap. I’m hoping a new seal will rectify this problem, but I’m also wondering if it would be related to the idling issues and the fault codes or is that a separate issue?
I’ll try to get the car over to my mechanic as soon as I can but thought I would share my predicament in the hope that it might help to get it sorted out.
Thanks and a Happy New Year to everyone!
Robert.
Robert.
