R.E92 said:I doubt that plugs are the issue though. Best advice would be to extend that warranty.
You were right, it wasnt the plugs. I was taking the car to the dealer for some other warrenty things to be fixed and the missfire got so bad the engine warning light flashed - I think it was the first and possibly the last time I was glad to see that happen! Dealer read the engine codes and diagnosed faulty injectors and replaced all 6. All a bit lucky as the excess free warrenty ran out late December so it could only be claimed because the missfire had been experienced but not properly diagnosed then.
Meanwhile, they also found the gearbox oil seals were weaping oil, easy enough to fix except to get access you have to remove the exhaust and the catalyst retaining studs had rusted on. Solution? A whole new cat because they cant get the studs seperatly to the cat! Especially entertaining as the exhaust system isn't covered under the BMW used car warrenty, but they've had to honour it's replacement facilitate fixing the seals. All in all over £2000 of parts and labour
