When warm the engine power drops off at around 6.5k.
is this normal?
is this normal?
Easty-5 said:Nope most definitely not normal. The S54 should keep pulling right up to the limited. Peak power I believe is hit at 7000+ RPM.
...and will hit the limiter at about 8100rpm.wspohn said:Easty-5 said:Nope most definitely not normal. The S54 should keep pulling right up to the limited. Peak power I believe is hit at 7000+ RPM.
7,900 rpm power peak.
mmm-five said:...and will hit the limiter at about 8100rpm.wspohn said:Easty-5 said:Nope most definitely not normal. The S54 should keep pulling right up to the limited. Peak power I believe is hit at 7000+ RPM.
You're right, my data logger hasn't logged anything higher than 7988rpm.Beedub said:mmm-five said:...and will hit the limiter at about 8100rpm.wspohn said:7,900 rpm power peak.
I'm sure the limiter is at 7950.... but i could be wrong....
Fishy Dave said:Mine shows about 8050rpm at the limiter on data overlay taken from the OBD.![]()
I don't think the ECU datalogger is inaccurate. If you take the engine to the redline with the throttle wide open, the ECU will cut the ignition at say, 7950rpm, whilst you disengage the clutch which will permit the engine to continue to rev more freely, so it's not unusual to see the rpm in excess of 8,000rpm but the engine will not be loaded on the those revs above the rev limit.Fishy Dave said:See 2:47, 4:17, 7.33 and others in my video here: https://www.youtube.com/watch?v=IQXCalSHSXg
It could be that Harrys or the OBD Bluetooth dongle is inaccurate or delayed (guessing upper edge of the revs)?![]()
exdos said:I don't think the ECU datalogger is inaccurate. If you take the engine to the redline with the throttle wide open, the ECU will cut the ignition at say, 7950rpm, whilst you disengage the clutch which will permit the engine to continue to rev more freely, so it's not unusual to see the rpm in excess of 8,000rpm but the engine will not be loaded on the those revs above the rev limit.Fishy Dave said:See 2:47, 4:17, 7.33 and others in my video here: https://www.youtube.com/watch?v=IQXCalSHSXg
yes you can raise the rpm redline on manual but not autos with a ECU remap one of the benefits having manualhopz121 said:Could have been mapped/coded to have a higher RPM?
goldbcfc said:yes you can raise the rpm redline on manual but not autos with a ECU remap one of the benefits having manualhopz121 said:Could have been mapped/coded to have a higher RPM?
