Hi all,
I'm posting this to help anyone that might have the same unusual issue I had yesterday. I was driving home from work (an hour commute) and 10mins from home the car starts intermittently jerking and losing power. I get home and leave to to run idle seems fine
strange... So I turn off the car I plug in my OBD scanner as I get a P0420 code error every now and then saying the bank 1 threshold is below standard. My cat is fine passed emissions test great a couple of months back plus I use redex in every tank of fuel to keep it clean. So I go for a spin 30mins later and the car judders 4 times before I get to 3rd gear. So back into the driveway I go. My mechanic picked it up on the tow truck today.
I thought it might be the usually cause of a misfire so troubleshooters, spark plugs, fuel injectors, camshaft sensor, mass airflow senor, compensatior cap, fuel pump or filter. None of these were the cause, it turned out to be the DTC. The ECU didn't know where to send the power and caused the engine to misfire. My mechanic is working on it now I'll update you guys if there are any other issues.
