Hi All I have posted this problem previously and have had plenty of advice on here as to what the problem could be. The car in question is an 04 plate 2.2 zed. I have had this misfiring problem since February, the rev counter fluctuates between 500rpm and 1000 rpm when idling, and it is a heck orf a job to keep the engine running. I had an diagnostic check done with adelphi software and it produced an error code 2783 Air Mass Meter Hot Film Intermittent . So I replaced the MAF Sensor the error code reset and didn't come back however the engine ran just the same.
I then noticed there was a tear on the Air inlet hose, so that was replaced however the engine ran just the same. I have today replaced the cam shaft cover gasket and fitted a new battery and a new set of plugs and the engine is still misfiring. I tried driving it down the road just to see I only went a few yards before the car was jerking as if there was kangaroo juice in the tank, so I reversed it back into the garage.
So to list the parts replaced : Air inlet hose, MAF Sensor, Cam Shaft Cover Gasket, Battery, Set Of Spark Plugs.
I am really at a loss now and don't know what to check next, all ideas would be greatly appreciated.
Many Thanks
Many Thanks
