Engine Light 2009 35i
RAYK47
 Hertfordshire
Hi all
Just wondered if anyone could help with the results of my scan, i used a paid app call Car Scanner. My main concern is the first one initially but i dont know why it says inactive) after it. I have left the modules where nothing was found in the log in case it helps with any other questions.
I am a complete novice with this stuff.
Car Scanner ELM OBD2
Version: 2.1.28/42001028/GP
DTC report
Connection profile: BMW OBD-II / EOBDDate: 21/06/2026 11:09:55
VIN:
OBD-IIOBD-II
DTCs: 2
U0129 [0xC129] Archive (inactive)
Data bus, brake system control module - no communication
Lost Communication With Brake System Control Module
Status: Permanent
3100 [0x3100]
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Engine control unit
No DTC found.
Transmission control unit
No DTC found.
No DTC found.
SRS/AirbagSRS/Airbag
DTCs: 1
C947 [0xC947]
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
IPDM/Junction box (JBBF)
No DTC found.
DSC/Traction control
No DTC found.
Fuel pump
No DTC found.
Convertible top
No DTC found.
ABS/DSC
No DTC found.
Parking brake
No DTC found.
Steering
No DTC found.
Telephone
No DTC found.
Audio amplifier
No DTC found.
Car access system
No DTC found.
Bluetooth
No DTC found.
Center roof module
No DTC found.
Gear selector switch
No DTC found.
High beam assistHigh beam assist
DTCs: 12
A7C8 [0xA7C8]
E0C4 [0xE0C4]
E0C7 [0xE0C7]
E0D4 [0xE0D4]
E0D5 [0xE0D5]
E0D6 [0xE0D6]
E0D7 [0xE0D7]
E0D8 [0xE0D8]
E0D9 [0xE0D9]
E0DA [0xE0DA]
E0DB [0xE0DB]
E0DC [0xE0DC]
Dashboard/Instruments cluster
No DTC found.
Central gateway
No DTC found.
Infotainment system
No DTC found.
Parking sensors
No DTC found.
Central electronics
No DTC found.
Central module (in driver's footwell) (FRM)
No DTC found.
Infotainment display
No DTC found.
Climate/heater/Air conditioning
No DTC found.
Right B-pillar safety module
No DTC found.
Well looks like either the DSC has died or something else on the data bus is dragging it down..
Needs a full ISTA class network scan to see which networks / modules are on line and which are not..
