Engine Light 2009 35i
RAYK47
Active member
 Hertfordshire
Hi all
Just wondered if anyone could help with the results of my scan, i used a paid app call Car Scanner. My main concern is the first one initially but i dont know why it says inactive) after it. I have left the modules where nothing was found in the log in case it helps with any other questions.
I am a complete novice with this stuff.
Car Scanner ELM OBD2
Version: 2.1.28/42001028/GP
DTC report
Connection profile: BMW OBD-II / EOBDDate: 21/06/2026 11:09:55
VIN:
OBD-IIOBD-II
DTCs: 2
U0129 [0xC129] Archive (inactive)
Data bus, brake system control module - no communication
Lost Communication With Brake System Control Module
Status: Permanent
3100 [0x3100]
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request
Engine control unit
No DTC found.
Transmission control unit
No DTC found.
No DTC found.
SRS/AirbagSRS/Airbag
DTCs: 1
C947 [0xC947]
Status: Pending fault present during this driving cycle, Validated and stored in non volatile memory, Validated fault present at time of request
IPDM/Junction box (JBBF)
No DTC found.
DSC/Traction control
No DTC found.
Fuel pump
No DTC found.
Convertible top
No DTC found.
ABS/DSC
No DTC found.
Parking brake
No DTC found.
Steering
No DTC found.
Telephone
No DTC found.
Audio amplifier
No DTC found.
Car access system
No DTC found.
Bluetooth
No DTC found.
Center roof module
No DTC found.
Gear selector switch
No DTC found.
High beam assistHigh beam assist
DTCs: 12
A7C8 [0xA7C8]
E0C4 [0xE0C4]
E0C7 [0xE0C7]
E0D4 [0xE0D4]
E0D5 [0xE0D5]
E0D6 [0xE0D6]
E0D7 [0xE0D7]
E0D8 [0xE0D8]
E0D9 [0xE0D9]
E0DA [0xE0DA]
E0DB [0xE0DB]
E0DC [0xE0DC]
Dashboard/Instruments cluster
No DTC found.
Central gateway
No DTC found.
Infotainment system
No DTC found.
Parking sensors
No DTC found.
Central electronics
No DTC found.
Central module (in driver's footwell) (FRM)
No DTC found.
Infotainment display
No DTC found.
Climate/heater/Air conditioning
No DTC found.
Right B-pillar safety module
No DTC found.
Well looks like either the DSC has died or something else on the data bus is dragging it down..
Needs a full ISTA class network scan to see which networks / modules are on line and which are not..
I have been contemplating selling her recently as i could do with something a little more practical, but i am struggling to come to terms with parting with her. I guess it depends on the cost of the repairs, if its a lot i will keep her as the market is not great and i wont get a decent price anyway.
so I decided to start her up as she had been barely used for a few weeks. Started up (needed a jump mind you) and the engine light was no longer on, so i took her for a spin, fully expecting it to come back on during the drive. However the light did not come back on. to the garage for the MOT today.
Took her to the garage for the MOT this morning and still the light has not come back on. not sure what happened and i have never heard of an issue just disappearing but i will take it. Will be nice to use her a little bit more, i pretty much stopped driving her as soon as the light appeared.
I bought my mum a Volvo V40 D4 to replace her Aygo, and it had an intermittent check engine light. It would come on every now and then, but there was never any noticeable change in how the car drove, so I'd just scan it and clear the fault code.
It's probably been about a year since the light last appeared, and the car is still running as well as ever.
Obviously that might not happen with yours but it is possible I suppose. :LOL:
MOT failed front near side shock leaking. Price quoted £1020 (including MOT etc) £621 for the shock and apparently like rocking horse poo to get hold of. .
Near side front shock absorber (strut) electric needed. Can anyone advise on a suitable alternative.
I nearly fell off my chair.
Sachs now offer the electronic versions for about £400 ish a pop..plug n play ..plus fitting of course
Car is back with a shiny new MOT certificate. She is running beautifully.
Good news Ray 👌
I’ve had the engine light pop on a time or two too, car ran as sweet as normal so I ignored it, wasn’t on the next day, same the couple of other times it’s done it, if it’s misfiring different story bit some are too quick to throw the panic mode out and pay lots for nowt, these are old cars now relatively speaking, a sensor misbehaving every once in a blue moon now isn’t a drama if the cars running properly.
