B Billbob10 Member Millom Cumbria Apr 26, 2021 #1 Hi.has anyone had a problem with the engine cover nuts just turning but not undoing. If so how did you sort it?
A AveZ4coop Member Peterborough Apr 27, 2021 #2 If it is the plastic engine cover and you have an e85/6 they are quarter turn screws. You only have to turn them through 90 degrees to release them. Try turning one slowly with very little pressure on it to see if it 'pops' out?
B Billbob10 Member Millom Cumbria Apr 27, 2021 #3 Thanks mate but mine have normal nuts on them. Cheers Bill
B Billbob10 Member Millom Cumbria Apr 27, 2021 #4 Thanks mate but mine have normal nuts on them. Cheers Bill
S Smartbear Lifer a barn in Somerset Apr 27, 2021 #5 Billbob10 said: Thanks mate but mine have normal nuts on them. Cheers Bill Click to expand... You shouldn’t need to touch those fixings, the engine cover just pulls away from some rubber grommets if you want to remove it. Rob
