rally-chris said:The cylinder head was revised on the later black top N52 engines, to help reduce the aeration issue in the lifters that can cause the ticking noise on early engines. Also the crankcase breather is different and more integrated into the cover that the silver top version.
Chris
Chris
Smartbear said:rally-chris said:The cylinder head was revised on the later black top N52 engines, to help reduce the aeration issue in the lifters that can cause the ticking noise on early engines. Also the crankcase breather is different and more integrated into the cover that the silver top version.
Chris
Hi, I think your getting mixed up between the actual valve cover (black ones incorporate the ccv as you say, silver ones do not) and the plastic cover which sits on top of the valve cover which doesn't signify anything![]()
biojo said:silver cover has CCV seperate and metal rocker cover
black cover have plastic rocker cover with built in CCV
that was my under standing, mines blck and yes if not used in a while in hot weather you get the ticking
