Engine Bay cleaner
patriot66 said:
Start with a cold engine. Spray 10:1 diluted TFR (Traffic Film Remover) under the bonnet and all round the engine bay. Agitate any particularly grimy areas with a stiff brush. Pressure wash everything thoroughly.
+1
I also use rubber gloves over any sensitive electrical bits to keep the water out
Gustavo7 said:
I used Gunk engine degreaser (spray version), let it work for a good 5-10min, rinsed it with a pressure washer from a distance (so low pressure was applied), turned the engine on to dry it all out. Sprayed Aerospace 303 protectant and wiped it all immediately.
regards,
Gustavo
Looks good, Gustavo - if it helps, you can actually leave 303 to dry and solely need to mop up drips/runs if you over use it. This way of working will provide a more uniform finish.
