Other than for CICENET does not work with E-Series
??Other than for CIC
You are right that the CIC is (should be) wired directly to the OBD socket. But the ENET cable doesn't work with the programs that work with E-Series, so the average owner cant do this, the only thing that may work with it in that way would be, as mentioned above, an ICOM and that is an expensive piece of kit.I could well be mixing things up but I thought I read something about CIC being the only module in an E chassis vehicle being ethernet enabled. What I failed to account for was the fact that the OBD connector in the E89 is no doubt not wired for it.
