Electronic water pump
Hi I have a E85 n46 4 cylinder 2.0 z does it have a electronic water pump I’m not sure. My heater takes ages to get hot my fan works ok the system has been bled all pipes are hot pipes to heater core are hot also thermostat fine so why doesn’t it get hot
Hi is that we’re you disconnect both rubber hoses at the bulkhead and flush them out- in one out the other. Will I have to bleed system after Flush I don’t do complicated is it straight forward. Cheers
You should start to feel a change in the temperature as the needle climbs out of the blue bit on the dash.
