A long and complicated tale:
E85 2.5i. Unfortunately the battery was left to go flat for about a week.
Recharged and tested, all seems good.
Initial problems..........
No wipers, no lock or unlock, windows won't go up or down, lights work ok, but no indications on the dash and no dash lighting. Airbag light on the dash. Interior light comes on when you open the door but won't go off again.
Scanner 1.4 can only see DME, ABS, LEW and IKE.
IKE shows 3 codes - 87(135) Body Bus (k-bus), BE(190) Data-filing difference to central light module (LCM), 20(032) Airbag lamp)
Codes reset but cycle the ignition and they all come back.
Fitted a replacement Star 12Low GM5.
Now the windows work ok BUT only when one of the doors is open! Close the doors and nothing happens. (At least now it is waterproof)
Swapped the battery from my car and the problems were the same.
Radio says 'disabled' on the screen. Reading that this has the potential to cause k-bus issues I unplugged it. No change.
If you sit inside the car with the doors shut you can lock and unlock from the central button, but the key does nothing.
From outside the car you can lock and unlock manually with the key in the lock.
If you lock it like this then the interior light does go out ok.
If you unlock it with the key in the lock and hold the key over the windows both go down.
If you then lock it by that method and hold the key over then ONLY the passenger window goes back up.
I am no electrician and have only my google fall-back mode to rely on.
I am finding lots of similar issues and mostly it seems to be one of the modules connected to the k-bus causing the issue.
The only option seems to be to unplug one wire at a time from the k-bus connector and see which one lets everything work again.
Where is this k-bus connector? Is it a relatively simple, slow and steady process of elimination?
Anyone encountered it before and got any tips?
At this point I'm baffled tbh.
