I have a 2003 Z4 2.5 that has been basically flawless until last night. After my long day at work I got into the car and immediately noticed a very predominate humming sound in the cockpit. I had not inserted the key into the ignition and everything in the car was off. I searched the car to find the passenger door twitter to be the source of the noise. Again with no key in the ignition I hit the radio button and the radio turned on and played
?!?!?!?(noise stopped at that point). I turned off the radio and the noise returned after about 10 sec. I turned the car on and there was a noticeable lag (only a couple of seconds) but the car started normally. I drove for 20 miles with no issues. But when I stopped the sound returned. The radio is stock and there has been no modifications to the system. At this point I figured a cracked wire to the speaker. But this is where is gets weird.
When I turned the car on again the headlights did not turn on. They were on automatic and have worked without issue up to this point. I turned car off and back on and on the third try the head lights came on but the gauge lights did not (rest of dash worked correctly). Off and on, off and on…the car started, headlights on, but not the gauge lights. Frustrated, I left it alone for an hour and checked again. Now the humm is going strong when I opened the door, starts fine, headlight go on, and gauge lights work. OK . But I turn it off now the humm returns and the gauge lights STAY on. :| Off on, off on, they remain on. I am now even more confused so I wait an hour and try it again, they stay on. During this off and on process I turned light switch to each of the positions with no effect, I moved the gauge light dimmer through the entire cycle and no effect. Then as I sat there wondering what to do next, a loud 'pop' went through the radio speakers (car was OFF no key in the ignition) and the lights turned off, buzzing stops and all is quiet.
This morning the buzz was definitely present, the lights worked and the gauge lights turned on. Tonight turned it on no headlights on automatic, no dash lights, buzz still there, radio works without key. Headlights do work if turned to manual on but no dash lights. Radio when car is turned on shows –I- on readout but when turned off the radio plays ??????
I have NO IDEA where to even start on this. :evil:
ANYONE????
Is there a fire risk in this should I disconnect the battery???
ANYONE????
I took her in subsequently due to tracking issues only to find that the rear passenger wheel was way out of alignment. I got that fixed but also was advised that the rear tire was worn excessively due to the misalignment. I run 235/19/35 and 265/19/30 so they had to be special ordered. The new tires arrived but when they were mounting them the same rim cracked! While I could have had it welded up the rim was noticeably bend as well. SOOOO called Elliott at ModBargins and he hooked me up with four new rims but they too were back ordered so it took a couple of weeks to get in. (Side bar: Elliott is great to work with, kept me informed of the process and even gave me a sympathy discount on the order!!!)
