Had my 3.0si 2006 roady for 7 months now and have had an intermittent fault that has gradually got worse
. First manifested itself as a reset of the clock to --:--, so researched on this forum and found that could be an early indication of a failing battery. Car always started ok, if a little sluggishly, so thought change battery and all will be well. Before had chance to change and during a drive about a month ago, speedo, rev counter, fuel gauge, temp and clock stopped working, all stuck where the instruments had stopped working. No indicator flashing in the car, but all lights working fine outside the car. Air con and heater fan ok, engine functioning fine, electric seats, heated seats, power steering, windows, radio all fine. Speedo stuck on 70mph, rev counter on 2700ish. Stopped, switched off engine no change, all frozen. Drove home, disconnected and reconnected battery, everything reset to normal. Thought, I must change that battery.
Bought a new Bosch S4 from Eurocarparts, fitted, thought my problems are all over. Err.....no they're not.
Problem still exists, same issue has happened another 3 times, never when I start car, always more than 20 minutes later, when driving. Have had all warning lights briefly illuminated and then frozen as above. Only electrical item that doesn't seem to work is the roof and the instrument panel. Has only happened when the roof is down, as it's a sunny weather only car, but don't think that has any relevance. Simply disconnecting and reconnecting battery has reset everything ok each time.
Any help, advice or similar experiences and remedies appreciated.
