This is good advice. Plug a code reader in and see if there is anything logged as it could be starting to fall l without you realising. Our X3 had codes logged in the background but we weren't aware of a problem until the car shut the engine down while the missus was on her way back from the school run. Engine went into limp mode in middle of busy road and scared the sh1t out of her. Thankfully it was only a 30 zone and very close to home but what an utterly sh1te design.Smartbear said:85genius said:Bloody hell, I just selected not yet, then read everyone's posts and now I'm wondering if mine actually is on its way out?
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=95532
Get your car hooked up to a decent diagnostic machine, the pump logs codes if its failing. Overheating is bad for these engines![]()
GreyZed said:This is good advice. Plug a code reader in and see if there is anything logged as it could be starting to fall l without you realising. Our X3 had codes logged in the background but we weren't aware of a problem until the car shut the engine down while the missus was on her way back from the school run. Engine went into limp mode in middle of busy road and scared the sh1t out of her. Thankfully it was only a 30 zone and very close to home but what an utterly sh1te design.Smartbear said:85genius said:Bloody hell, I just selected not yet, then read everyone's posts and now I'm wondering if mine actually is on its way out?
Apparently the on board electronics fail in these pumps and stop the comms to the ECU so even though motor and impeller may have years left in them the unit becomes scrap.
Crazy Harry said:Marlon said:Crazy Harry said:My 57 plate 3.0 is just shy of 40K - seen quite a few comments on here about the N52 engine/pump so was planning to change mine at 50K and call it planned maintenance :wink:
living up to your name there :wink: Thats one hell of an expensive 'preventative maintenance'!
Not in my world! last time I looked they were £227 on flebay http://www.ebay.co.uk/itm/ORIGINAL-PIERBURG-ELECTRIC-COOLING-WATER-PUMP-BMW-X1-X3-X5-Z4-N52-7-02851-20-8-/152456081420?fits=Plat_Gen%3AE85&hash=item237f17300c:gPYAAOSwcUBYQD6Z.
I rate the cost of a breakdown away from home; possible overnight stay or late back via relay; or an unknown garage putting spanners on my car if they have the part - let alone a spoilt run out to be worth changing it early. I'd rather change my own at a time of my choosing![]()
GreyZed said:The stats are fine it's the electric pumps that are ill conceived and flaky pieces of crap.
DMC63 said:E85, 84k, Water-pump was still working and in good condition. Took the car in for a cracked thermostat housing, Dealership fitted a new water pump too (I offered to pay but they stuck it on the AA parts a labor cover).![]()
Smartbear said:DMC63 said:E85, 84k, Water-pump was still working and in good condition. Took the car in for a cracked thermostat housing, Dealership fitted a new water pump too (I offered to pay but they stuck it on the AA parts a labor cover).![]()
Hi, your car doesn't have the electronic water pump this threads talking about :wink:
DMC63 said:Smartbear said:DMC63 said:E85, 84k, Water-pump was still working and in good condition. Took the car in for a cracked thermostat housing, Dealership fitted a new water pump too (I offered to pay but they stuck it on the AA parts a labor cover).![]()
Now I feel left out, rejected, less thanAnd slightly embarrassed
That would explain the rubber band thingy going round the end of it from the engine.
That's probably why it hadn't failed. It wasn't electric. Less to go wrong. Hehe.
bobo075 said:Mine seems to work well but the car is 10 years old so i just ordered a new pump and a new thermostatwill fit them soon
Roundozo said:bobo075 said:Mine seems to work well but the car is 10 years old so i just ordered a new pump and a new thermostatwill fit them soon
I wouldn't bother replacing it until it goes. It's an expensive piece of kit. You current one could be fine for years to come.
Smartbear said:Roundozo said:bobo075 said:Mine seems to work well but the car is 10 years old so i just ordered a new pump and a new thermostatwill fit them soon
It's expensive, but not as expensive as a replacement engine after it's been cooked!![]()
Roundozo said:Smartbear said:Roundozo said:I wouldn't bother replacing it until it goes. It's an expensive piece of kit. You current one could be fine for years to come.
Yes but that's like saying "I'm buying a new gearbox, just in case it goes". There's preventative measures and then there's overkill. If money is no issue then i suppose it's up to the person. I personally would just keep an eye on engine temps. He does state it's "working fine" so why replace something that's not broken.
