No, i meant more that you could establish if it is in fact the coilpack by swapping with number 5.archieuk84 said:Chris_D said:Good move archie. I know how disconcerting it can be pulling ur engine to bits for the first time and ive also gleaned most of my knowledge from youtube how-to's.
Good that you id'd the 6th coilpack but did you actually swap it for a good one to confirm its actually the coil and not the sparkplug or cable?
No, not yet replaced it as i don't have a spare and as i said i will get a dignostic tool to confirm before i order parts...but based on what i have read its highly likely to be the issue.
If you notice a change in the engine note by energising then de-energising cylinder 5 with coilpack 6 then you can assume its the coilpack.
If you dont notice a change then it's the number 6 sparkplug, cable or other issue.
a diagnostic tool/software could also confirm this of course. I think you're going to be looking for generic 'misfire' codes though which can point you to several totally different issues.
