eBay vented discs kit
madmutt0
Has anyone bought and fitted the drilled and grooved brake kits that are sold on eBay
164 uk pounds for front and rear with pads seems good value are there any benefits from fitting them
If they're the mtec discs then yes, I have them fitted currently. They've been perfectly fine for my driving. Not had an issue. They're probably the same as oem in terms of braking performance.
+1
+2
+3
I fitted them with the anti corrosion covering and had brake judering for a while. I deglazed the pads and made sure the discs where very clean and have had no further problems. I like the product and look.
If I did so again I would not bother with the coating but would paint the non braking surfaces with heat resistant paint to avoid rust.
It is also worth looking at mtec website as the items were cheaper than eBay when I purchased.
