easy HID fitment kit?
Yeah - I misread the way it was worded. In reality best is HID on low and high.
OEM xenon does both low and high of course with one beam, using a shield that raises up and as the beam is inverted by the lens cuts off light to the top right.
Strangely and probably as I live in a rural area see no need for dipped HID and benefit most with great high beam performance.
What about fuses being upgraded? i fitted a 35w hid on my e36 and upgraded to a 20amp fuse,
would this not be the case again bearing in mind theres 3 fuses for the lighting system?
Leon, dragging up an old thread.
did you do this conversion? i found these on ebay. my bro has them fitted to a supra and caldina and they look great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160575336887&ssPageName=STRK:MEWAX:IT
i think the z4 takes H7? if so does this mean any H7 kit will fit the zed?
I think any H7 kit fits any car designed to take a H7 bulb, but a non-Z4 specific kit might run into problems with triggering the bulb out on the dashboard. Specific kits usually come with some sort of device that fools the car ecu into thinking a normal halogen bulb (which draws more current) is still present.
I can't view the above link so can't comment (work firewall!)
yea i bought a HID kit and it was slimline so fitted in behind the light.. thing was it kept flashing all the time, i needed a BMW HID kit, that has the decoder on it.. think they are on ebay for £70.. not tried it yet though!
