SOLD E92 M3 seats - should fit the E89
Sold
damocell
 Chorley, Lancs
Pair of black leather, electric E92 M3 seats, good condition, no major rips or anything like that, should bolt straight into a E89 I believe.
£240 collected from Chorley in Lancs
Apologies but have you actually tried to fit them into an E89? Alternatively did you use Google etc. to at least check if they might?
I'm not going to put it out there without some sort of fact to base it on :rofl:
Although I don't know about the wiring, I'm fairly certain they will bolt in to the floor based on my research. However, I am not 100% certain and haven't tested the theory. That is why i wrote "should" rather than will.
They do share a lot of seat parts so I'd say it's pretty likely they will fit, can't find a definitive answer on the seat rail itself though for fitment and I would probably want to do some measuring and check bolt layout etc first. The seat wiring seems to be shared between E9x and E89, so that should work.
Thanks for this, I thought similarly.
I'm happy for someone to come to mine in an E89 and we can try the fitment before they buy if it helps
Realise you are in the SW, so probably not helpful to you, but putting it out there for others.
Have you still got these seats? I’m local to you and could do a test fit. Are they heated seats? Mine are heated black sports seats and have electric operation for side bolsters and airbags. The main adjustment is manual, but I guess if your electrically operated seats plug straight into the loom then the electric operation will probably work.
Hmmmm. Just had a google and it seems to be not so straight forward. The seat height is likely too high also and the e89 is cramped at the best of times. Perhaps not.
highly doubt they'll fit.
different seat rails/ anchor point
also e89 seats are narrow compared to standard beemer seats, so it may be a squeeze.
reason:
This summer and last, Ive been trying to figure out whether f82 m3 seats will fit into our cars.
They bolt straight into e90/ e92, but not an e89.
which means the e92 seats above wont fit.
wiring is not an issue, its more the physical constraints.
However you might be able to find adapter brackets or have them made.
