E89 window switch unit
noz85
Does anyone know if these are a common part across a few different cars and not solely for the E89? I am looking for a replacement, and it would help if I could confidently widen my search, rather than looking for E89 party only.
https://www.aliexpress.com/item/1005008095802852.html?spm=a2g0o.productlist.main.51.28f4NtCNNtCNnJ&algo_pvid=6d4ac046-3412-4622-bdc8-1a05908a65db&algo_exp_id=6d4ac046-3412-4622-bdc8-1a05908a65db-25&pdp_ext_f=%7B%22order%22%3A%22-1%22%2C%22eval%22%3A%221%22%7D&pdp_npi=4%40dis%21GBP%2113.98%219.09%21%21%21122.74%2179.81%21%40211b81a317381361605682186eac97%2112000043705931838%21sea%21UK%212215704532%21X&curPageLogUid=c5GmNAzyTkPW&utparam-url=scene%3Asearch%7Cquery_from%3A
Says...Electric Power Master Window Control Switch Regulator Lifter Button For BMW Z4 E89 3 Series E90 E91 E92 E93 61319217365
Blimey that is cheap. Wonder how likely it is that it would set on fire :lol:
Thanks for the link though!!! Quite tempted with the suggestion I saw elsewhere of a bit of contact cleaner on the faulty one first
The switch appears in a couple of other E series BMWs..but..there are also different variants depending on options..
See pic..best to look at realoem.com and get used to how to source parts :thumbsup:
Nothing wrong with the Aliexpress one, I'm running one in mine, been in a while now and is perfect :thumbsup:
Contact cleaner...does it have contacts? Might just be rubber bridge like key board or hall sensors.
Only time i had problem it was the connector being the door card, poor connection on negative pin.
Thanks for the replies. [ref]AnubisZed[/ref], Interesting vouch for the Aliexpress switch! Worth a punt then!
Only issue, the one in the link looks to be the power folding mirrors version. My car does not have this feature. I have the 9216107. Or is it just a case of removing the button?
B21 said:
noz85 said:
I didn't think there was any software requirement for these?
The switch has a micro controller in it..that has firmware inside it
I am sure i read another thread yesterday where the same question was asked and AnubisZed said it wasn't the case.
https://z4-forum.com/forum/viewtopic.php?t=137346
In which case fine.. :thumbsup:
