E89 roof won't open
Dacos
 Toulouse
Hello ! I have a 2010 E89 Z4.
Since a couple of weeks, the roof doesn't open anymore. When I press the open button, windows go down and then, nothing... Doesn't even try...
The light of the opening button goes red (not everytime) and no message.
Once, my trunk refused to open, but only happened once.
My battery is not the issue, I check the fuses, and I ordered "salmon relays" to replace them, they were quite old. Hope it will solve the problem.
Any ideas what else it could be ?
Yes, I know Cahors. Nice town ;-)
I am trying to solve this, maybe the salmon relays will solve the problem.
Tell me when you come if you come. Thanks a lot
Just changed the "salmons". As you predicted, it didn't help.
Hello again !
Just received the OBD reader. Got 3 errors for the roof:
A690 / A692 – Hall sensors => correction left and right microswitches
A698 – Roof open
Got a lot of other errors also, not for this section... Need to check them also.
Gonna look through the forum how to fix this :thumbsup:
A690 and A692 are the left and right boot closed micro switches. Cheap and easy to replace, once you get the roof into service position.
Here is a tutorial I did.
Sorry to hear that BMW parts prices have exploded. I paid $25 each about 3 years ago.
I seem to have a "battery" issue... I am looking into it
I have the A559: KL30g_f shutdown error code that keeps coming up even after resetting the errors codes.
My battety seems ok, a check by a professionnal says it is ok, with a "battery state of 92%" (state, not charge level)
But:
1/ I have the "low battery warning" after 2mn if I don't start the engine + OBD reader sats battery level is 35%
2/ after the heavy rains yesterday, I have water in the battery compatment, wasn't there 2 days ago
But:
First step almost always on E89s with mysterious electrical problems is get a new appropriate battery ..then see what happens..
But:
Also check the little storage compartment on the left hand side and also under the trim on the right where the parking and roof modules are, if there’s water there then it’s probably the seal around the top edge of the boot that leaking, the sealant dries out and turns to powder, also check the rubber seals around the rear lights, it should be seated around both sides of the bodywork.
My battery has been changed 2 years ago, still under warranty, car starts perfectly, OBD values are "voltage 14,59V" "voltage measured by IBS 14,83V"
Does not seem a battery problem to me...
Could it be because battery is stronger (80Ah) than the 70Ah standard ?
The 80ah battery definitely won't cause a problem..but..your readings from your OBD reader suggest inconsistent battery status ...
So often on E89s a simple A/B swap helps eliminate gross errors
Varta is a very good brand and it seems unlikely..but..it happens all the time..
As Chippie said corrosion on the CTM connector pins or water inside the CTM MAY be issues..again we've seen them here
Can a wrong battery status bring other problems ? Roof opening ? Others... My OBD reader gave me a list of errors and I am checking them all...
Engine electronics
30C6: 0x30C6 engine oil pressure sensor, plausibility
2A19: 0x2A19 Tank venting valve, control
2A94: 0x2A94 crankshaft sensor, signal
2D27: 0x2D27 air mass meter
2AA8: 0x2AA8 variable intake system actuator: control
2AA9: 0x2AA9 Variable intake system positioning motor 2: Control
Soft top module
A690: Hall sensor VSW5.1
A698: Top hatch open
A692: Hall sensor VSW5.3
Dynamic Stability Control DSC8 Plus
5F1C: 5F1C - Info entry: Active brake intervention for overheated brake discs.
Instrument cluster
Engine electronics
Soft top module
Instrument cluster
On my 35is when I bought it ..it had 145 errors..most cleared with a new battery and error clear
Clear the errors and see which come back
