RobbiZ4 said:Smartbear said:Hi, not wanting to watch the endless repeats on tv over the crimbo period, i thought I’d change the 2 salmon relays that operate the roof.
The first thing to do is clear the boot of any blankets etc![]()
You can see the salmon relays in this pic, the white coloured clips are fiddly to release in this position
If you undo the T25 torx securing the mounting bracket the job becomes a lot easier
Hi Rob, there is a much easier way without using a tool:
just press the black clip on top of the two red wires on your 2nd picture. By that you can slide out the whole unit.![]()
Rob, another thing:
you have to look at the inner relay contacts as these are the critical ones. The outer contact shown on your picture is not of any interest.
In between we have taken a video of an opened relay @work:
[youtube]https://youtu.be/zKQVfM9CK64[/youtube]
Background info to the complete relay story:
https://bmw.spoolstreet.com/threads/urgent-recommendation-to-replace-the-pink-hardtop-hydraulic-relays.3815/
My original post in German:
https://www.zroadster.com/forum/threads/z4-e85-e89-z8-e52-1er-2er-3er-e93-4er-f33-6er-e64-f12-minir57-ersetzt-die-dachrelais-alle-2-5-jahre-durch-neue.133521/
Translated by Google:
https://translate.google.de/translate?sl=de&tl=en&u=https%3A%2F%2Fwww.zroadster.com%2Fforum%2Fthreads%2Fz4-e85-e89-z8-e52-1er-2er-3er-e93-4er-f33-6er-e64-f12-minir57-ersetzt-die-dachrelais-alle-2-5-jahre-durch-neue.133521%2F
I've just been reading through your posts, it says to change these relays every 2 years whereas in other places on this forum I have read to change it every 5 years or so. Should they really be changed every 2 years? I would have thought relays should last longer than that. Anyhow the stealers contacted me today, mine have arrived this morning so it will be a job for me to do over the holidays.
